https://tascam.jp/int/product/hi-res_editor/top
Try the free Tascam hi-res editor, works for windows and Mac.
@ericrosenfield , check these posts, THD should be magnitudes lower. There must be something odd with your build. Did you check the voltages?
I was playing with QA403 (an audio analyzer) and tried a few things with my ACP+. I noticed there is something happening ~18kHz. It does not seem to be related to the power supply and the input. I tried both a battery and wall mount switching power supply, and I do not see this when the analyzer is in loop back so it is not related I guess to the source. Is this normal, why would be the reason for this ?
ACP+ powered with battery, no input signal:
ACP+ powered with battery, and with input signal from the analyzer:
ACP+ powered with wall mount switching...
ACP: CAP-TASTIC EDITION!
The past few months I've been slowly learning Kicad and doing some PCB layouts for fun. I originally decided I wanted to make a dual rail (bipolar supply) version of the ACP. It turned out really nice, but its not an ACP anymore. ACP is one of my favorites, so I decided to take a shot at a more 'by the book' version, which is what you see here. It turned out well and sounds fantastic (just like the original).
For the most part its the stock circuit, though I did tweak a few things:
- Added some gate resistors to the LTP (ode to ZM 🙂)
- Swapped a K170 for...
I get 0.1V across both R12 on both sides. R13 rises up to 0.6V before falling down to 0. For current, I get 0.2uA on R12 while R13 jumps up to 40uA before dropped down rapidly to 0. This is also consistent on both sides. I have no idea if that's good or bad.@ericrosenfield , check these posts, THD should be magnitudes lower. There must be something odd with your build. Did you check the voltages?
It's entirely possible I did something wrong, though I don't know what it might be. Also I didn't measure the distortion until after I'd changed the caps, so I don't have a measurement before the mods to compare to. (In case I did something wrong when modding.)
EDIT: When I turn the volume knob all the way up the voltage on R12 goes up to 0.15V.
@ericrosenfield , just to be sure: In your build, R12 is 2.2 ohms and R13 is 6.8 ohms?
What kind of voltage meter are you using? Is it capable of measuring in the mV range?
If the resistors are what is in the original schematic, the values you measured are too low. But there might be an error in the measurement as well if your voltage meter is not appropriate.
Also, what do you mean with "for current, I get 2.2uA..." Measuring the voltage across the resistors is supposed to tell the current, when applying Ohm's law (I=U/R). Do not try to measure the current directly.
The current through the resistors R12 and R13 needs to be around 150mA for proper setup. So for the 6.8 ohm resistor the voltage across it should be around 1V and across the 2.2 ohm it should be 0.33V.
Jumping to 0V also is weird.
Also, for clarification: You built the 24V version, not the one that was posted in this thread that uses a +/-12V supply?
That's what the bands on them say@ericrosenfield , just to be sure: In your build, R12 is 2.2 ohms and R13 is 6.8 ohms?
It's a Klein multimeter. It's pretty good.What kind of voltage meter are you using? Is it capable of measuring in the mV range?
You can see how if you ask me what the current is, the most logical thing to do would be to set the multimeter to current mode and measure it? Anyway, okay, I'll calculate it next time.If the resistors are what is in the original schematic, the values you measured are too low. But there might be an error in the measurement as well if your voltage meter is not appropriate.
I mean, it's possible I don't have the probes firmly on it or something, but that's the behavior I'm seeing. I should try again with alligator clips, but I'm leaving town and won't have a chance again until I get back week after next.The current through the resistors R12 and R13 needs to be around 150mA for proper setup. So for the 6.8 ohm resistor the voltage across it should be around 1V and across the 2.2 ohm it should be 0.33V.
24V. That's what my power supply is putting out, that's what the ACP+ is getting.Also, for clarification: You built the 24V version, not the one that was posted in this thread that uses a +/-12V supply?
Assuming that the voltage is too low--what should I do about it?
@ericrosenfield , no offense, but I wrote this
I think what needs to be done is a basic health check of voltages in a couple places (which also tell current through the diff stages).
Just ping here when you have time. I will post a schematic with voltages how they should be and you can post how they are and we should be able to sort out what needs to be adjusted.
The 2nd line is telling how to calculate current from he measured voltages.Measure voltages across R12 (Ur12) and R13 (Ur13).
Current through them is Ur12/R12 and Ur13/R13.
Just in case...You can see how if you ask me what the current is, the most logical thing to do would be to set the multimeter to current mode and measure it? Anyway, okay, I'll calculate it next time.
That may seem intuitive, but you did not tell us exactly how you measured the current. If you set your DMM to current mode and place the leads across a resistor, that's not how to measure the current through that resistor. If you did that, you'd have effectively placed a very low impedance / resistance "wire" in parallel with the resistor. Don't do that. In a lot of situations, you can cause too much current to flow through the circuit and damage parts.
If you wanted to measure the current through the resistor using your DMM set to current mode, you'd need to lift one leg of the resistor and place the DMM in series with the part. It does not seem as if you've done that. It's MUCH easier to measure the voltage across the part and calculate the current from the known voltage / resistance as described.
You may know that... but your results seem suspect, and others may interpret your statement to mean that they could measure the current directly.
That’s exactly how I tried to measure current and I had no idea I wasn’t supposed to do it that way. I have no training whatever. Appreciate the correction.That may seem intuitive, but you did not tell us exactly how you measured the current. If you set your DMM to current mode and place the leads across a resistor, that's not how to measure the current through that resistor. If you did that, you'd have effectively placed a very low impedance / resistance "wire" in parallel with the resistor. Don't do that. In a lot of situations, you can cause too much current to flow through the circuit and damage parts.
PCM to DSD conversion - I successfully implemented this AK4137 board into my dac for PCM to DSD256. Very simple and easy to do. You need a receiver that accepts the PCM signal and sends it I2S to the AK4137 board and an export board that accepts I2S DSD conversion from AK4137 and sends in HDMI-lvds (configuration that matches destination pin-out, mine is "B" configuration ps-audio/IanCanada dac ReceiverPi DDC). I used LHY audio boards for that, ianCanada has his own with better more expensive engineering.Anyway, the short answer is that I've not been able to meaningfully compare DSD and PCM on my system.
https://www.aliexpress.us/item/2251...opMoreOtherSeller|query_from:#nav-description
I would suggest that you don't convert PCM to DSD using 4137 and then draw conclusions from that
You're going to probably hear differences in the conversion step rather than PCM v DSD
And even with PCM recorded music v DSD it can be a murky well as although I have got the same "high quality" recordings in PCM and DSD (or at least it was sold) the PCM was audibly mastered worse, rather than the format being worse
And it was sold as hifi recordings... Probably got scammed on the 24/96 PCM one 😆
(PS : I used to have proper dacs that took both, now i don't care if they don't after I sold it)
It's been noted that this board is a poor implementation of the chip. But it's all I have to work with in the current market, until somebody else develops a better board. That said, this board radically improves my audio, but I have excellent wiring, shielding, grounding and power filtration. In my setup I'm very happy with it. I actually have priority for television/cinema online streaming material via spdif/toslink so real time conversion, HQ player for music is not an option. It does improve the audio from a wall-like sound with strong highs (without the board) to a more 3-d holographic sound with stronger bass and not so fatiguing high frequencies (with the board), for now it will work.I would suggest that you don't convert PCM to DSD using 4137 and then draw conclusions from that
If I could program an FPGA chip then this thread has a much better board and project instructions:
It's nice to present this project - separate delta sigma modulator for a dsc2 dac.
Special thanks to Jussi and Pavel.
The basic idea is to convert pcm to a dsd stream without the use of a PC.
Design flow goes as follows:
i2s serial data is converted to parallel, next we have the first interpolation fir filter,
in this filter the data is oversampled x2, x4 or x8 - this depends on the incoming data rate.
(for 44.1kHz we have x8 interpolation, for 96kHz x4 and for 192kHz x2)
next, the data is going to the two stage CIC filter and is oversampled x32 to final x256
Then the data is going...
- olo111
- Forum: Digital Line Level
And this thread as well PCM2DSD and DSD2PCM evaluation board:
Hi All,
Recently, on the market is available premium SRC AK4137 from AKM (Asahi Kasei Microdevices).
The chip is interesting since it is not only the SRC but also converter from PCM to DSD and DSD to PCM
I wanted to test it, but AKM don't have any Evaluation board or Starter kit for this chip.
So I decided to design my own Evaluation board.
AK4137 features:
-PCM / DSD conversion function
-conversion from 2.8/5.6/11.2MHz DSD to PCM format, and vice versa.
-Maximum Sampling Frequency, Bit rate: PCM768kHz/32-bit, DSD256(11.2MHz)
-DR: 186dB
-THD+N: -150dB
-Sound Color Digital Filter: 4...
AK4137 features:
-DR: 186dB
-THD+N: -150dB
- JarekC
You see the source selector switch, but not the power switch. Plug the part number into Mouser and take a look at the data sheet.
The initial version of the ACP+ did not have a power switch. 😉
^ Any time. Enjoy the build. IMO, this is one of the coolest projects around.
Looks like my ACP+ might be dead. I plug it in and I get a voltage at the power switch, but there's no voltage at the LED or anywhere else. Also no sound.
I took out the LED and put it into a breadboard and confirmed it still works fine. Something ain't right. No idea what happened, I don't think I did anything to it but I given the build quality I might have looked at it funny and it decided not to work anymore.
Oh hey nevermind it's a blown capacitor.
This cap blew and got replaced once before. Not sure what's going on there.
- Amp Camp Pre+Headphone Amp - ACP+
