Hello,
One channel of my amplifier has a significant buzz/hum when initially turned on, then subsides after 1-2 seconds.
What can be the cause of this?
Please help me find the problem... if it is even a problem
both channels do it, however one is significantly louder than the other.
What should I look for?
There was a soft-start on a relay, but I disconnected it as it became unreliable (occasionally needing a tap with a screwdriver to engage). I intend to rebuild that with a manual switch instead. I understand it's due to inrush current and started the same time I disconnected the soft-start, but my only concern is that the one channel is significantly louder, and would like to diagnose this if it is a problem before proceeding to re-implementation of the soft-start switch, I'd rather not ignore it by masking it. Also no oscilloscope on hand.
Can tube filaments cause this, maybe I'll start by swapping L to R tubes see if there's a change to the other channel.
BTW all diodes and capacitors seem to balance well enough without dismantling for accurate measurements...for now.
