amp board for 2x15w 6Ω speakers
An advantage with the smaller tpa3116 class d boards is that they typically run from an old laptop power supply (18 - 20 volts). Something to keep in mind is that these boards require a speaker load at all time when powered.
Op mentioned keeping soldering to a minimum, while maintaining a low price point, something to keep in mind before adding posts maybe, if wasting bandwidth bothers you.
Other class-D amps to consider are those from Yamaha, YDA-138, YDA-148, and T-amps like TA2020, TA2024. Boards cost less than a hamburger, and are basically ready to plug and play. Combined with used speakers from yard sales/thrift stores/dumpsters, you can have very decent sound for ridiculously little money.
With any of these cheap amp boards, it wouldn't be unreasonable to run some basic performance tests on them, since a magazine reviewer determined that his amp came with improper output inductors that severely affected the frequency response.
Considering the OP wants to use this system with his laptop and some cheap speakers, I wouldn't even worry about high fidelity specs.
Using a laptop as a source doesn't preclude high fidelity, and while I'm not familiar with his speakers, it's not unusual to find decent (even Stereophile-reviewed) 2-way speakers at thrift stores and yard sales for under $10 a pair.
I found the article: Australia's "Silicon Chip" magazine, May 2019, page 38. "Bargain Class-D Stereo + Subwoofer Amplifier Modules" using TPA3116D2. Treble was rolled-off, measured at 8 dB down at 20 kHz. Changing the output inductors from 55 uH to 10 uH fixed that. Other problems noted were poor channel separation at high frequencies (maybe due to coupling between the output inductors), and the subwoofer channel amplifier wasn't correctly configured for mono operation.
