American Bass 500.1
Ok the muting transistors are fine .
I started looking at the audio driver board .
I found Q4,R21,D2 bad so far .
Wondering what would cause these parts to go bad ?
The owner stated the amp worked when he pulled it out of the vehicle he just saw a flash that’s why he brought it to me .
There is no way this amp worked when he brought it to me with these parts on the audio driver board being bad .
And since those parts are bad anything else I should check ?
This is the driver board that uses 4 of the IR21844S’s
I blew the outputs again same bank so I’m gonna rebuild the driver board replace the outputs again .
There is also stuff that is defective on the main board by the muting transistor I found 1 of the diodes to be leaky .
Is the MMBTA42 on the audio driver board a sot-23 package ? Or a sot-23-3 package
