Amazing opamp measurement shoot-out
Amazing work and results. I hope the author will keep up with more opamps (there are quite some [worth evaluating] devices, in particular from AD and TI).
Nothing really surprising, only the LT1115/LT1128 are dissapointing and somehow conflict with my own measurements (but then I did not evaluate the common mode linearity and the input impedance linearity).
I also hope the discrete opamp manufacturers will send samples for evaluation (to help answer the third question) but somehow I doubt they will...
Anybody asking "but how does it sound?".
Great Paper with very interesting commentary.
Interesting how quickly things degrade once you start to drive heavy loads and/or high output levels on most of the devices..
I might be wrong, but it looks like the AD749 comes out tops overall and the LME4xxx from Natsemi a creditable 2nd place.
The author also commented that extra care is needed on the AD device. I think th e NS device is a bit easier to use, so thats what its got in its favour.
As mentioned alreadt, congratulations are in order to Scott Wurcer!
There are a few very strong contenders for the first place that were not yet evaluated:
OPA211, THS4031, OPA827, OPA2822, OPA842 from TI
ADA4899-1, AD823, AD8066, AD8610, AD8599 from Analog Devices
EL2227 from Signetics/Elantec
...and probably more...
Did anyone notice the unbiased and unbypassed 6800uF caps in the test circuits?
Unbiased, do you mean the + of the 6800uF should be more positive than the - of the 6800uF? How can we do it in a simple cct?
