Hi All,
That's my first post so please forgive me if I won't be using the correct terminology.😀
I would appreciate if someone could help me out with my first DIY DAC project. I would like to connect the Amanero to my DAC (Littledot DAC I which doesn't have the I2S connection) via the following WM8804 I2S to S/PDIF Converter:
WM8804 S/PDIF TOSLINK to IIS Converter I2S Codec Project integration DIY | eBay
Would you please be so kind as to explain to me how I should make all the required connections and which type od connectors I should buy?
Many thanks in advance for your kind help!
