Amanero (DiyinHK Isolator) Soekris dam1121-02
Hola,
A simple question I should imagine, but I am a DAC noob:bfold:
I can't get signal out of a Amanero > Soekris dam1121-02 DAC - or rather I can just hear a signal at max volume - so something is happening. I have a DiyinHK Isolator board which may or may not be the issue, so I am attempting bypassing it with not much luck. I assume that I have the incorrect wiring.
Attached a couple of crude schematics (PDF/JPEG)- what am I doing wrong?
Thanks for any help.
_Ben
  • Soekris Pin Layout DAC_03.pdf
  • Soekris Pin Layout DAC_04.pdf
Joined 2009
Hola,
_Ben
Maybe connect analog power, won't work without.... See manual for details.
Hey! It worked!
Thanks a bunch Soren - it's a great DAC, spent some time listening tonight: the timing and calm resolution are very apparent - looking forward to tweaking it up!
We all appreciate the great work that you have done here - I've always much preferred the R2R solution, and this one is really great.
_Ben
