Hello,
I have for sale 3 aluminum pcbs for Salas SSLV1.3 shunt regulator. To assemble these easier I offer also the stencil.
Each pcb hosts a positive and a negative regulator.
I designed the pcbs because I use them in an application where high dissipation is needed and the project uses an aluminum enclosure to host everything.
I attached the pcbs directly to the side panels which are very effective heatsinks.
No electrical isolation is needed.
I will provide the bom and schematic to be used to assemble the pcbs.
Sold
Sold
Hi schultzsch, which size are the pcb?
Did you use any hard to get parts?
Can you provide the gerbers?
Hello @baggerbole,
74x60mm
No
Unfortunately I didn`t get the accept from Salas to share the gerbers.
74x60mm
No
Ok, thanks for your quick reply.
I have some trough hole boards left and the parts. So I´ll stay with them
