Aluminium for front panel
Great link byu, but you wouldn't happen to know any european adresses like it? It'll cost an arm and a leg to ship the metals to europe from the US, especially if you like the look of copper on your DIY-stuff 🙂
Jouch - try the local phone directory for telephone numbers on companies in your area that does aluminium work. Try contacting them - i´m pretty sure you can find a (smaller) company that will help you, especially if you can do all the machining yourself and just need a piece of metal that will roughly fit the dimensions.
Good luck!
/Uffe
PS: If you want to have the metal anodized, try contacting a school that teaches mechanical engineering - sometimes they are just dying to get something they can play with in their expensive equipment....
It's a tough item to find. The best is to get a local shop go through their inventory and see what they can cut out for you. The problem is also that you can't shear-cut aluminum that thick and make it look good, so the rough cut piece has to be finished on the mill. Unless you have a mill handy you need to have the shop do it for you. I did mine in the student shop at the university and it took me 1 hour to do it but I am no expert machinist and the aluminum was only 5mm thick.
Finish
Metal in Norway is very very expensive, probably worth shipping from US actually.
Also, consider finish. It is often hard to get decent finish. Are you going to anodize -- or paint? If you paint, you can get around it but still ...
