Alternative material for stators?
Looking for suggestions for a inexpensive alternative to perforated sheet metal stators.
Haven't been able to find any perforated sheet metal in my area without having to make a special order which is quite $$.
I was thinking about steel fly screen for windows (if they even make that any more).
Any thoughts?
This is not what you're looking for (too expensive), but I have been playing with the idea of using a perforated carbon fiber/resin (epoxy or polyester) composite panels for stators. I just finished building a bicycle using the stuff so I've learned how to work with the materials, and I have some scraps to play with. Hmmmm. Maybe this winter...
The perforations are always the tricky part. CF/resin is not particularly hard on tools, so some sort of CNC step and repeat set up for drilling might be possible. Another way might be to make a "mold" with pegs (nails?) all over the place. Just lay the cloth in with the pegs poking through it then pour on some epoxy and spread it around. The trick would be making sure you can take it off the pegs when the epoxy has set.
Another way might be to mount the cloth on a frame, pull every other "thread" out of the cloth, and then apply resin. This would leave lots of holes. CF cloth loves to come apart when you're working with it, so this technique might work well.
The CF cloth is conductive. I measure 30-50 Ohms between my meter probes placed a few inches apart on a small piece of cloth. I think the resistance is unlikely to affect the sound.
5.7 oz./sqyd CF cloth typically sells for $35 per running yard in small quantities. I estimate that a single layer, 1 sqyd piece of CF/resin composite would end up weighing about 8-9 oz if it is vacuum bagged, and a few more ounces if not.
Another way might be to buy CF "roving" and use it the same way the wire stator guys use wire, but then apply resin after the "weaving" is done. This might have some advantages over wire stators in that it would weigh less (maybe NOT and advantage) and has very nearly zero coefficient of thermal expansion (not much advantage if the speakers sit around at room temp all the time anyway- maybe good for car audio?).
I_F
"The CF cloth is conductive. I measure 30-50 Ohms between my meter probes placed a few inches apart on a small piece of cloth. I think the resistance is unlikely to affect the sound." ...I_forgot
Would the cf/epoxy stator need to be painted with a conductive coating?
Keeping in mind that the secondary circuit of an ESL (from step-up transformer to stators) is an extremely high impedance environment, small resistances are probably not of any consequence. Think of it this way: If the ESL’s step-up ratio is 1:75, and let’s say each stator has as much as 500 ohms of resistance from secondary to stator surface (1000 ohms total in the secondary loop), that would equate to 1000/(75^2) or 0.18 ohms in the primary circuit. That would be less than most tube amp’s output impedance, and probably typical of a solid state amp plus cable. The DCRs of both primary and secondary will compete with these values too. I think a few tens of ohms in a carbon conductor stator can generally be forgiven, although some means of distributing voltage so that all points on the plane of the stator have close to the same resistance presented to the diaphragm surface might be useful.
What about using CF rods to build the stator?
An array of small carbon fiber rods arranged horizontally would make for an interesting look. And couldn't one bow the rods to make a curvilinear panel?
What would the effect of pushing sound around these cylindrical surfaces be?
Cody
I_Forgot, a caution that you may have already considered:
As you know, charges concentrate on points of high curvature (charge density is proportional to the radius of curvature), such as in lightning rods. The tiny cut tips of carbon fibers would certainly have extremely high curvature. If these points, even one or two, were allowed to face the diaphragm, I believe they would encourage corona formation and possible arcing. Even if the fibers facing the diaphragm were continuous, they still have high curvature in one dimension. If continuous fibers are woven or placed very close to one another relative to the stator-to-diaphragm distance, you may be OK. The electrical properties of the binder or resin that you use to hold them together will certainly effect the behavior.
I was reminded of this concern by a device I have. It is an air-ionizer/cleaner. It uses a weak high voltage supply connected to a small exposed rope of interleaved carbon fibers that is wrapped around a plastic insulator. Here the designers were using the high curvature properties of the carbon fiber to create coronas. And it works. You can hold your hand nearby the rope and feel the electric “wind”.
I’m not trying to discourage you at all. In fact, I think if you’re careful to address these corona concerns, you may have an excellent approach. Of course, this brings us back to Beveridge. Suppose you used a more homogenous conductive additive to epoxy? Could powdered graphite be mixed in sufficient quantities to give low enough resistance without making the mechanical properties go to hell? Inquiring minds want to know…
I would embed an electrical contact to the CF in the composite, so there would be no need to add a conductive surface over the CF/resin composite.
What would the effect of pushing sound around these cylindrical surfaces be? Cody
There are a few commercial speakers that use metal rods or tubes for stators, so CF rods should work fine. I don't think they would make a very efficient speaker because you need to allow some space between them which means the area they present to the diaphragm will be relatively small, like using a large mesh screen for a stator.
There are other problems- where do you get them at a reasonable cost? The retail price is quite high. On the other hand, fishing rods can be pretty cheap, and if you collected enough old ones from local garage sales you might eventually have enough of them to make a speaker. You might be able to get rejects from rod manufacturers in Taiwan pretty cheaply. Fishing rods are tapered, so if you kept the spacing between them even you'd have a speaker that was wider at one end and narrower at the other, which might look nicer than a plain rectangle.
As for sound squirting between the cylindrical surfaces of the rods- should be no problem. In fact, with perforated sheets, those little holes actually form cylinders, thousands of them all the same size, that have some specific resonance frequency. A series of rods should have no such resonances. But then again, what about the resonance of the spaces INSIDE the hollow rods? Hmmmmm.
Curved panels are another set of problems, the biggest being curving the diaphragm while keeping it under tension. Martin Logan does it, but not for the reason that most people think. Curving the panels doesn't broaden HF dispersion much. The HF beaming is primarily a function of the width of the driver- it always was and always will be. The real reason to curve the panels is to make them stiff. A flat steel panel would be very wobbly (I know because I have built some that way). Curving the steel makes it stiffer. Try it with a piece of paper.
If you're making stators out of CF rods or tubes, you can make them flat or curved easily and without having to bend the rods/tubes, unless you want the panels curved in two dimensions. The real problem is making the tensioned diaphragm do that. If you figure out a way to do it (maybe using air pressure?) what have you gained besides a nifty bit of marketing copy?
I_F
After a visit to the local hardware store, I think I will use a roll of Aluminum stock. I have a small piece of perf that i can use as a stencil to drill the holes into the stock myself. If I do all 4 stators at once then it shouldn't take too long to do. I can get 50'x12" for $40. The stuff is flimsy enough to be rolled length wise but it should stay nice and flat on the frame of the speaker.
I_F
I guess this means my idea of using the aluminum fly screen wouldn't be a good idea?
Too bad, it was only $9.99!!!
furly
I think you have conductive coated plastic fibers in that device.
Real carbon fiber material, whether it is just roving or cloth, is too hazardous to be put in a home environment without having a binder like epoxy or polyester resin completely covering it. CF cloth is made of coarse tows consisting of 3000 or more actual carbon fibers bundled together. Individual fibers are very stiff for their diameter and will break and fly off as "dust" (actually needles) from simple handling/flexing. The dust is very sharp because of the small diameter of the fibers (the 3000 fiber tow is maybe 0.1 mm diameter) and is a severe irritant to skin and mucous membranes. I have inhaled those little ******s a couple times and the coughing fit they induce would make them suitable for use as nonlethal crowd control weapons.
CF cloth should be handled with gloves, long sleeve shirts, a dust mask, and eye protection. The dust is conductive and will cause all sorts of problems if it gets into electronic devices.
Your point is valid. It remains to be seen whether the resin in the composite would control corona. It's just one more reason to build a test panel.
I_F
I've done some googoling and the C/F composite looks interesting.
I'm thinking about a 6" panel mounted in a plywood baffle to get
some bass out of this width.
You can get pre-pregnated panels, .014"x6"x48" for under $50
a pair. Or even cheaper if .007" thick. Drilling the holes in a panel
this size might not be daunting and minimal dust in case the GF
with asthma walks in my small condo, or worse if one of the cats
jumps in the act....
Would .007" or .014" thickness be stable in a panel this size?
Otherwise you can get them thicker but bigger $$.
Lucius
AFAIK, pre-preg panels are CF cloth that has been wetted with epoxy. They are shipped frozen to keep the epoxy from setting. I don't know where you would get something like that in onesy-twosy quantities- they are usually used by CF plate and tube manufacturers who buy in quantity.
What you will get is probably a rolled up piece of epoxied cloth packed in dry ice. You'll need to roll it out flat on a surface that the epoxy won't bond with and it would probably be a good idea to have a similar flat surface to put on top of it and squeeze it flat. Pre-preg stuff is used when minimizing the weight of the final composite part is important. That isn't really a concern here, so why pay extra for it?
If you're going to that much trouble you may as well just buy a yard of CF cloth and a quart of epoxy/polyester resin to mix yourself. It will cost less, and if you have a problem you'll have plenty of material to start over with. One running yard of CF cloth is usually 36" x 48-50" depending on the manufacturer.
I_F
"THE GRAPHITE STORE"...Also a good source for graphite powder, rods and a graphite
conductive spray. The panels are shipped with 1 face prepared for gluing.
You have a point on getting the fabric. Even if the panels are gift wrapped, someone
like me is likely to make a goof..Site is here....
http://www.graphitestore.com/cat.asp/spcat_id/2
Lucius
Cody
My posts in this thread are about panels, but the site I noted has solid rods
which might be a more efficient. You wouldn't have to go with what seems
to me a complicated crate & wire jig. Keeping my small system simple I would
go with the straight hoizontal look. Any simple ideas?
Lucius
