Alternate Driver for Jordan JX92S TL Cabinet
I am wondering if anyone knows an alternate lower cost driver that would work well in the TL cabinet design that Neil kaye did such a nice job of building as detailed in the gallery pages and his web site.
http://web.mac.com/noteldov/iWeb/DI...cts/B6A9F293-40AA-4D01-A250-5427951E0B11.html
I want to build a cabinet design that will fit hidden inside a wall with the driver area only stepped out 1/2" to be flush with the finished gypsum wall. This TL design looks like it would fit nicely in the wall. I would have to adjust the vent opening out the front as well.
The idea is to create what looks like a simple inwall speaker but in fact have the benefit of a TL design.
Re: driver selection
Inniswhe said:
The proposed driver is a FR125S. The shallowest cabinet design is what I am looking for . Sealed cabinet would be simplest to install if anyone knows of a design that has been proven.
Both the FR125 & the Fostex FE127 work in a simple ML-TL. You should easily be able to accomodate one into the walls -- i've actually done just that with a set of diyAudio Ref FE127e ML-TLs (port exiting closer to the ceiling so the kids won't fill the port with ...
http://www.diyaudio.com/forums/showthread.php?postid=528564#post528564
These could be cut in half (lengthways) and used for the FR125. FR125 also works well in sealed (10-14 litres)
http://p10hifi.net/tlinespeakers/FAL/box-plans/P10-FR125-bipole-MLTL-map.gif
dave
CSS FR125S ML-TL Modelling
In my work in designing, analyzing, and building a FR125S/WR125S bipolar ML-TL I do have a single driver ML-TL to describe. All dimensions are internal values:
Line length: 39.56"
Driver centered 14" from top
Port Located 37" from top
Cross-sectional area: 21.75 sq. in.
Stuffing density: 0.50 lb.-ft3
Port diameter: 2.125"
Port length: 3" (50 Hz F3) to 4" (45 Hz F3)
You can vary the port tube between 3" to 4" long depending on how low you wish to go for the 3 dB down point.
This design models very flat and will sound great.
Jim
Scottmoose said:
Dave, how about that WB 127 based folded quadratic taper design you did a little while ago? Should be ideal.
Yes, there are numbers for a Metronome for the FE127. As well i've drawn a Tombstone/PAWO format ML-Voigt for the FE127.
dave
