Altec Lansing Valencia vs. Heathkit AS-101
frugal-phile™
Joined 2001
GM?
They certainly look similar
dave
GM
Joined 2003
Greets!
Different cab, tuning, damping, XO with the Valencia's 'bright'/'thumping', 'in your face' 'West Coast Sound' Vs AS-101's somewhat smoother 'HIFI' sound that blended with a typical room much better as the excessive damping differences testifies. Note the Valencia's missing rear cover is covered with the same thin padding as the rest.
Note the two vertical slit vents the Altec horn creates Vs that area heavily stuffed to ~aperiodic loading in the 101s.
Reactions: 1 user
