Altec 601/604-like multicell horn dimensions and parameters - please advise
Joined 2008
I would like to try out a small single piece 3D printed multicell for a 1" CD as a tweeter for the large 5x3 multicell that is now waiting in my basement to be measured (some pictures here: https://www.diyaudio.com/forums/multi-way/136964-construction-multicell-horn-47.html). I would like to make a baby-multicell to match the visual style.
The Altec 601 horn is a 900 Hz cutoff, 3x2 cells, 60x40 coverage and around 10-12 cm width estimated from the pictures. It should be relatively simple to make a model of it, if I could get the dimensions more precise.
However, I am not sure if that is what I need. To match a 5x3 multicell with 12 cm cell size for use around 3 kHz and up, what would be some good dimensions to start with? Should it be a 5x3 cells, too?
If you want a little multi for a tweeter then matching the coverage of your midrange horn seems a good idea. Of course the higher you cross, the less it seems to matter.
There aren't a lot of examples to go by, unfortunately.
FWIW,
Historically, for HF // UHF duty, JBL moved to 60x30 deg. patterns in their later K2 super-tweeters that use small horns.
That ( using a narrowing of pattern for the UHF ) matches my own experience that achieiving good imaging doesn't rely on having wide UHF patterns ( once one gets, say, over 10K ).
Quite the opposite ( IME with Fostex tweeters ) .
The thinnest line is somewhere between 0.4 - 0.5 mm with a 0.4 mm nozzle. Now I am fighting (again) with the throat transition. I cannot force F360 to create a loft to my liking. I am trying to model the empty space of the horn to cut it out later from a solid block.
Don't know if anyone else around here ever compared multi-cellular horn sound with more open horn designs. Even for Altec 604, UREI Big Red Monitors used a custom horn mouth on the 604's that wasn't divided into cells. Of course, dividing up a horn into multiple cells gives more control over dispersion, but it always increased distortion to my ears.
So the model is finished, in the attachment, without any warranty that it is even printable. It was a challenge and I do not think I could do it under normal conditions, but I have now lots of time to waste🙂
  • OuterShell.zip
    OuterShell.zip
