Hi Guys
I recently picked up a set of accusound speakers which I have been pretty happy with. Unfortunately the Sub only goes down to 35 which isn't cutting it for home theatre. Before I take the drastic measures of buying a completely new sub/box/amp I was wondering if it would be possible to reuse the existing box and amp and just replace the driver? I have very little understanding when it comes to this kind of stuff but do know that sub drivers are very dependent upon the box and amp but I figured I'd ask anyway.
The specs of the sub can be found here (the reference 8 set)
http://www.accusound.com.au/signature.html
SUBWOOFER
Frequency Range 35Hz-150Hz
Power Handling (Watts RMS) 150 (built in 240V amplifier)
Bass Drivers 1 x 250mm Woofer
Dimensions (mm)
H 460
W 311
D 432
Weight (kgs per speaker) 24.2
The box also has two ports firing downwards.
Please let me know if you need any more details.
Look forward to your replies
SUBWOOFER
Dimensions (mm)
H 460
W 311
D 432
