Alps RK12L12A Volume Pot Required
Hi, can anyone point me in the right direction to buy an Alps RK12L 12A 50K ohm horizontal volume pot for my Nytech Obelisk.
Still love the sound of the amp but the volume pot is damaged.
Looked everywhere on the 'net but can only find the Alps "Blue". The one I require is the earlier version, picture attached.
Any help greatly appreciated.
OK how about this? What is wrong with the old pot? Broken shaft? Broken resist wafer? Broken wiper?
These little pots come apart by unbending the small metal tabs. Si if the shaft is broke, buy a new one of the same series - any value will do - and take them apart and put the new shaft in the old pot. Likewise a busted wafer, buy a wrong style pot of the right resistance and taper, and transfer that wafer into the old body and shaft.
I have done that many times over the years, and never had a problem. In fact I save the remaining new parts in my pot drawers in case some future repair needs the unused parts in similar manner.
Isn't this what you want?
RK12L1210C0L ALPS | Mouser
They are out of stock at Mouser, but they expect delivery by Feb 12, less than a month.
Thanks Enzo, I guess its the wafer that has been damaged, not removed the pot yet.
I will check out Mouser, its a volume pot I need but can buy the one from the link and have a go at stripping it down.
Thanks again, Mark.
You wanted horizontal, and the link is what I call horizontal - shaft parallel the board. 50k audio. How is my link different from your needs then?
If you want shaft perpendicular to the board, MOuser had those as well in the 50k audio.
