use a multimeter to measure resistance between the pins. Some of those pins could be just for mounting on a PCB
Use the ALPS part number printed on the pot to find out what the pin out is.
Just google the part number.
OK, there is no part number I could find even with the microscope.
And I read the value with the multimeter, but I do not understand the 5 pins. These are not mounting pins.
D.
D.
If it is a tandem pot it is probably two wipers, two feeds and one common.
I would say it was 9mm not 10mm which means RK09K12A0A2K is the model series.
Perfect thanks. I had never seen such part.
D.
- Design & Build
- Parts
- Alps Potentiometer
