Alpine PDX1.1000 powers on, no audio (IR2010s HELP)
The desktop and the power supply are plugged into the same outlet.
The speaker wires read 0 ohms to the deck chassis. I cleaned and reconnected the ground supply wire to the deck from the power supply and now get 0 ohms from the speaker wires to the amp ground terminal. Can I just connect an RCA male cable to the speaker wires and just use it at low volume?
That's why the computer and supply aren't connected through the mains. It's no big deal but you will have to use the ground clip on the scope probe when using the scope.
With the scope probe grounded to the primary ground on the amp, do you get a good signal when checking the signal on the audio caps AND the rectifier (different vertical amp settings, of course)?
Use only one channel of the scope.
With the ground clip connected to the amp ground, I get good signal on the rectifier, but not the audio caps. The audio caps signal looks the same whether RCAs are plugged in or not, volume high or low.
E301 tested with black probe on amp ground terminal.
First pic is settings, second pic is with RCAs unplugged, third pic is with RCAs plugged in at 0 volume, and fourth pic is with volume at 40.
