I will order the correct parts .
Can I use the regular 3205’s just for testing to make sure there are no other issues since the amp came in with 1 missing and the amp has low output on 3 channels
You can use whatever you'd like for testing. I sometimes used output FETs that survived failure in other amps but had to be replaced because they wouldn't match the new FETs.
I don't know if the originals were screwed down through the tab. If they were, you can't do that with the bare FETs.
Anyone have the service manual for this amp ?
There are diodes shorted , outputs shorted ect
ZD2001 is shorted
ZD2001 is shorted
