Alpine PDX-1.600
When I got this amp on it had all of the output filter caps blown in it .
I replaced them and get pulsing DC voltage measured across the output terminals
There are 2 driver ic’s for the output IR2010S
On 1 of the driver ic’s I get pulsing voltages also on pin 8 which HO pin
I tested the components in that area and all test fine wondering could the driver ic be bad or is it more likely something else is causing the pulsing DC on the HO pin ?
