Alpine MRP_M450
I have a blown Alpine MRP_M450 and I am trying to get it working. When it was first broken,the LED lit up but there was no output. I replaced the blown IRFZ44N output transistors. Now, no LED and the power transistors (which seem to be working) don't even warm up. Does anybody have the schematics for this model?
I figured out why my LED wasn't working, I got the polarity mixed up.
Voltage to PSU FET's (IRF5305's, right?) reads ~300 mA on the gate and ~700 mA on the source and drain, measured between ground and the respective leg. Value constantly drops the longer I hold the probe there.
I am having trouble identifying a driver without any schematics.
Okay, I'm assuming the power supply transistors are the IRFZ44N's marked Q601-604. Each has 12 volts going to the center leg. There are 2 more 44N's on the board, as well as 2 IRF5305's. None of these get 12 volts to the middle leg. Sorry about the mix up there.
Okay, I'll contact them today and see if they will give it to me.
I pulled 2 of the IRFZ44N's, the multimeter reads open leads unless I have positive on leg 3 and negative on pin 2. I need to replace these again, right? The amp seems to power up.
This is the biggest IC on the board - IC301.
http://www.st.com/web/en/resource/technical/document/datasheet/CD00169483.pdf
This 494 appears to be the controller.
UPC494GS pdf, UPC494GS description, UPC494GS datasheets, UPC494GS view ::: ALLDATASHEET :::
And there is this C847UG microcontroller...
View TMP86C847UG_4107501.PDF datasheet online --- IC-ON-LINE
Is this enough information to go off of? I can trace leads to the best of may ability if need be. Otherwise I'll probably put it up, it isn't worth paying for the service manual.
