Alpine MRD-M1005 mono issues
Amp starts, PS works, draws 1.1A on idle. Inputting any signal into the RCA --> amp goes into protect with CUR error.
I've read all of the threads for this amp in this forum.
I've lost a whole day measuring stuff and reading the schematics.
No shorted semiconductor parts, no shorted or opened diodes, blown caps or whatsoever.
There is no class D switching on the gates at the output mosfets/or the output of LO/HO IR2010S chips. Tracing stuff and comparing values to the service manual.
There is +4.2v at the collectors of Q301/Q302 instead of the -1.5v in the service manual.
IC301/IC302 have +4.2v at pin 6 -IN, instead of 1.5v in the service manual. OP amps supply voltages are correct.
Then IC303/304/305/306/307/308 voltages go haywire...
Firstly I thought it's MUTE error but Q305 voltage are right as in the manual.
Any help would be appreciated as i'm lost with this amp...
If you drive a signal into the amp, how far does it get through the circuit?
What is the DC voltage on each of the speaker terminals (black on secondary ground)?
The error in voltages is likely due to the fact that the feedback signal is not what it would be if the amp was working properly.
What's the DC voltage on all terminals of Q303?
If you drive a signal into the amp, how far does it get through the circuit? - should I attach the LCD display for this test or no ?
What is the DC voltage on each of the speaker terminals (black on secondary ground)? - no voltages on the terminals
1 - +4.8v
2 - minus 45v
3 - + 4.2v
Something else i've noticed - Q306 + Q901 + Q902 (2SC3421) are getting hot really fast.
Okay...
It's not the PRE-AMP section. I've traced the injected sinewave to here.
Blue circle is where it's still nice clean sinewave.
Red one is where it's only half of it and it's "below" ground. Like something is dragging it down.
Last picture is what I have at the output terminals. Something like a sawtooth wave below ground point --> this being an full bridge amplifier i was expecting a half rail voltage at each termial... ?!
If you connect a jumper from each speaker terminal to ground (preferably through something like an incandescent bulb, 2 bulbs), does your signal get through the op-amps?
So if I connect a sub as normally the client would do, is this going to be the same as connecting each speaker terminal to gnd through an incandescent bulb ? It's just easier for me. Wouldn't this also provide the feedback needed ?
Just asking, but i'll give it a go with the bulbs.
