Alpine 3542
It's not a normal transistor. It's a 'digital' transistor with internal resistors.
Are you sure that you have the pin numbering right?
If they're reversed, the transistor appears to be defective.
Confirm that the collector of Q314 is very near ground.
Ya I am using A1220A instead A1358 as A1358 was bad. Base is having 13.33v, collector is having 0.723v this pin is connected to 494. Emitter is having 7.74v.
The emitter should be connected to the 12v power source.
The base should be about .7v below the emitter.
The collector should be very near the emitter voltage.
Is Q313 getting hot?
The Q313 was reversed. According to the print on the board the thick line suppose to be indicating back of the transistor but here it is different. Amp came from another tech who stated to the customer that he can't fix. I found few parts were bad and replaced and after correcting Q313 amp is now coming on. But there is a difference in positive and negative rail by 4~5v. And on one channel it have 0.2v dc and on another 0.35v. But amp is playing now.
