Alpha Wire 7055 Voltage Rating
This is the response I got from Alpha Wire:
I apologize for the confusion. 150V is printed on the wire because the UL and CSA approvals are for 150V. So if you are using this in a UL or CSA application, it can only be used to 150V. However, the MIL-W-16878E approval on this wire is for 600V. So if you are using it for an application outside of UL/CSA, it can be used for 600V. The reason 600V isn’t printed on the wire is because the Military specification does not require printing, while the UL and CSA approvals do.
