alpha 5 Fault
Reply Dr.H
Hi DR.H,
Thanks for your reply, I think you are correct in your assumption, the tda1541a does get quite hot and there is no heatsink on the device. This contrasts with a friends Cambridge CD2 and CD3, which used four paralleled to achieve 16 times oversampling, each DAC had a large metal bar applied as a heat sink.
Many Thanks for your help.
