I think a good speaker need a notch filter.
Let see what we need.
Could you post a sketch or drawing of the filter please.
jeff
That image is very small. It's difficult to see the component values. No big deal, I was just curious.
jeff
jeff
LeifB60 pls give the pic of the filter which we can read...i will try it at home..,i have ALp 12 which is apsolutelly unlistenable..i have lost 7 years with this driver..
driver alone is not for listening at all...
i'm playing with the filter, 2.5mH //20 ohms for the start..
2.5mH // 6.8R is too sharp still for me..
LeifB60 for what is the parallel notch filter (60+33nF+2.43mH) i have checked in simulator.. doing something around 20kHz?
driver is mounted in KEF LS50 -like cabinet.. cca 20 liter.
2.5mH 0.1ohm bobbin is made from thick wire and double C cores with air gap..
i'm thinking to make Fostex 3"- Alpair 12P combo, where Alp. would be only for bass.. Fostex 83 SOL regardless of size, sounds much better.. more normal, not so irritant like Alp 12p
- Full Range
- Alpair 12P
