hello!
first...sorry for my english because I am french Canadian.
I want to make a box for my alpair 12
but I like électronic music like trentmoller, so i want to make a small box for have a fast and tight response.
its a bass reflex box of .636 cubic feet, what you thinks about that?
Well, it makes a nice, high tuned 0.5 Qtc sealed alignment, but you say it's a BR, so need the vent dimensions. That said, based on published specs this is too much volume (Vb) for a simple BR unless driven with a high output impedance, so are you?
GM
GM
the vent is 2 inch diameter and 4 inch long... its write on the first draw
you thinks its to much volume...can you explain to me why?
With this vent, it is what is known as an extended bass shelf (EBS) alignment which works well with either a high output impedance or in a low tuned (sub) woofer alignment, but not so much otherwise IME. I mean you can add damping to roll it off, but as is, it won't provide what I consider a 'fast'/'tight' response.
I'm not you though, so of course only one way to know for sure if it will meet your performance goals.
GM
GM
It should work OK. (as per GM, for my boxes volume maxes out at about 13 litres) I'd add some bracing
dave
dave
- Full Range
- alpair 12 box
