Hi Guys,
Can anyone recommend a budget friendly (if there is such a thing) Amplifier and pre-amp for Alon IV. I dont mind a DIY if need be.
So a clean amp. Still no idea where used, power handling of speaker, volume level. Not crazy pulling teeth, you have to give some requirement rather than say, 'I need an amp".
Sorry for sounding too ignorant, i am music noob. i am good with electronics but music is not my thing; i know good sound but dont know what it takes to get there. I just want a pocket friendly Amplifier that can get the best performance out of them.
Anyway this is the specs of the Speakers
Three-way, floorstanding loudspeaker.
Drive units:
1" (25mm) metal-dome tweeter,
5" (130mm) tri-laminate cone midrange,
12" (300mm) fiber-cone woofer.
Crossover frequencies: 400Hz, 3.5kHz. 5" (130mm) tri-laminate cone midrange,
Anechoic frequency response: 29Hz–25kHz ±3dB.
Low-frequency bandwidth (anechoic): –3dB at 29Hz, –9dB at 20Hz. Sensitivity: 87dB/W/m.
Impedance: 3 ohms minimum.
Amplifier requirements: 100W minimum, 200W recommended.
Dimensions: 48" H by 15" W by 18" D. Weight: 105 lbs.
Is this for home? Usually a guitar is not put through home speakers. The pocket amplifier suggests being portable, using the speaker with others? You still have not said how you will be using it. How much power do you want to get out of the amplifier?
I would do a Fet preamp and go into a switching amplifier powered by a SMPS.
I think "jazz" is on records and "pocket" is Money.
He wants a 100W-200W home hi-fi amp which is happy driving 3 Ohms. That's a moderately "special" thing.
Exactly
Sorry but you are in the wrong area of the Forum, this one is for Guitar Heads (and I´m talking the members, not the Amps 🙂 ), please ask moderators to move this thread to a more useful (to you) area.
The OP has started another thread here:
https://www.diyaudio.com/forums/solid-state/356393-100-200-watts-3-8ohms-alon-iv.html#post6251168
- Live Sound
- Instruments and Amps
- Alon IV amp
