Allo DigiOne and Hifiberry DSP Add-On Board
Hi @All,
Is it possible to combine an Allo DigiOne with a Hifiberry DSP Add-On board?
Background:
I've build a network player with a RPi 4, picoreplayer and the Allo DigiOne. I am very satisfied with the sound and usability so far, but I need to correct some frequencies and love to have all the given possibilities of a DSP.
I've tried to install CamillaDSP, but I just can't get it to run, no matter what I try. I don't know why.
I'm very much a beginner in terms of Linux and programming.
I know that Hifiberry also has a Digi board, but if possible I would like to keep the DigiOne.
Thanks in advance
Mare
Probably not. It has to intercept the i2s signals yet it's mounted over the DAC hat. I suspect the additional DSP board 6 pin connector and additional circuit in the DAC hat is how the i2s signal is routed via the DSP board to the DAC hat.
Thank you all for the replies so far.
I hoped it would be possible to reroute the data streams in the configs like the CamillaDSP does. Meaning the data output from the Pi goes to the DSP first and the to the Allo and out.
I haven't used the 10-Band EQ yet, because I wanted to combine the DSP with my REWmeasurements. But I guess I will have to use that, until I find a solution.
