This is how I made an all-in-one projector. The original projector was a Infocus Litepro 770. The are other similar Infocus projectors but the key is that they all like look like this:
I was also given an insignia 7" lcd protable dvd player. The backlight and speakers were later destroyed in an accident but all of the other components work great. The anti-glare film was also strippable.
I made a frame using picture framing matboard and glue to secure the 7" lcd to the original mount
I used telephone wire to extend the cables from the lcd to the dvd player
The dvd player was mounted outside
Finally finished
Much cleaner and nicer to look at than if I built my own box
Here it is next to my future retrofit, the ASK 970 projector. I'll be looking for a 10" portable for this one.
Finally finished
Let see some images
Lights on
Lights off. Note uniform focus and brightness. SDE is noticeable, but that's simply because of the limitation of the lcd display, which I believe is only 234i
5th element with lights on
off angle shot. Again notice the eveness of the image. Little if any noticeable hotspotting
Lights on
City shot
dark scene shot. This image is much more viewable in real life
The portable is nice in that I can connect external video sources to this unit
hdtv shot (crappy, unfortunately)
video games, ie gamecube
The nice thing about this lcd panel is that it has a fast speed, so I'm not noticing any delay during fast gameplay
Daytime viewing
Note the offset of the projector relative to the screen. Unlike most diy, where the centerline of the projector is the ceterline of the screen, I can leave this below the bottom of the screen, just like a commercial model
Whites aren't totally white, but still more than acceptable
As you can see, text on a 234i res lcd isn't the greatest, in fact it pretty much sucks. Stick to movies or text larger than what you see here.
animation is bright and clear
So how big an image can these projectors display?
How about 150"
So how much did all this cost in the end?
Portable Insignia 7" dvd- $0.00 (a gift)
Telephone wire + additional parts- $0.00
Matboard for the framing- $0.00
Infocus Projector (from a computer surplus store) - $50.00
Total- $50.00
How about 150"
Total- $50.00
And if anyone wonders how does it compare to a zoombox- here is your proof:
Infocus image
Zoombox image
Both units were tested on the same screen with roughly the same image size (Around 65" diagonal)
Victor
Infocus image
Zoombox image
Victor
great!
but you can go on upgrade. the original lamp is 3500k, 60 hrs.
you can get a short arc MHL.or HMI
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- All-in-one semi-diy projector
