Hi Everyone...
Well this is my first post to let you know what my plans are,
Basically, I want to build a complete "All In One" Mixer/Scratch/PC, (With folding screen)
I have been busy researching schematics and implementing my own with a few tweaks, I have attached these. I have tried using CAD (hopeless case), so did it using Excel, it gives you an idea and I can easily adjust it.
For the Mixer sofware i will either be using PCDJ or VDJ, hence alot of the main mixer controls will be map'd via MIDI utilising stripped USB Gamepads.
The PC will be a SFF motherboard along with some of the features (USB cards, Dual Monitor outputs CD drive etc)
Internal and external Speaker options/ Headphones(controlled via PC Outputs)
OK now for the help.....
On the schematic, I want to introduce a Reverb circuit for the microphone inputs - All individually controlled (1 in 1 out type of thing)
I dont want and echo, echo, echo but I want a fading away toneeeeeeeeeee lol
Please help, I really have no idea about this bit, I have tried to find an analogue/mono schematic to no joy....
many thanks and thanks for anticipated assistance..
Chris.😕😕😕
Chris.😕😕😕
I think VDJ has effects in it so you wont need an external echo circuit.
Hi and thanks for the response, Vdj does have an effects panel
However I will not be running the Microphones through the PC, inturn VDJ won't have an effect on the vocals, hence the requirement for a Pcb/schematic that is built into the main input schematic.
Chris.
Circuit design (CAD) Updated
Hi All
Have finally got a CAD program (lol) have looked at a few things from what people have been saying, trying to understand them and using the diagnostics on the program I have attached the following schematic..
Am I getting close...
Please please please,, if I have made any errors,, can you explain in the simplest terms possible as I am learning. Please explain certain weird and wonderful terminology lol
thanks and really appreciate all of your help.
Chris.
Hi All
Chris.
LM358 pins 2 and 3 need swapping.
Corrected,,, are there any more?? are all the values correct aswell as Capacitors. Do I need to have + polarised caps???
Chris
Chris
Make all capacitors 1uF and above polarised the rest are best none polarised.
Okay - Circuit Updated again...lol
Have actioned all suguestions,
hows it looking now??
many thanks
Chris
many thanks
Chris
many thanks
Chris
Looks better.
Anyone else got any comments ?
- Analog Line Level
- All In One Mixer/PC Project
