All fet super buffer
Hi all,
I have problem with this construction:
http://www.borbelyaudio.com/pics/EB-602-403 final.pdf
Buffer working good,but DC stability isn´t very well!When I switch on at out is 240mV and going down to 0V.After two minute stable on 3-25mV.Still going up and down.I did two this buffer ,and doing this both of them.
excuse my english,
regards,
Help is easy : 'cos EB like to listen DC signal :D, all his connections are DC coupled...If you make feedback loop not as " DC " and connect R 7 through some larger capacitor ( elyt + foil in parallel ), problems will be away....Second solution is to get this buffer into thermoisolated box with regulated constant temperature... :D
Hi Mr.PD,
when I construct All fet line amp ,there is not problem with DC.But there is DC servo.In super buffer I make feedback loop.Gain 6dB.I put this Buffer in TopDAC.
I go try to put there capacitor.
Thanks for help
P.S.Second help looks fine!:D
