Hello, Any idea how the damping factor of the Pass Labs' Aleph 4 is calculated? Many thanks.
A alanyeoh Member Joined 2004 2004-08-17 9:06 am #1 2004-08-17 9:06 am #1 Hello, Any idea how the damping factor of the Pass Labs' Aleph 4 is calculated? Many thanks. ••• More options Share Nelson Pass The one and only Joined 2001 Paid Member 2004-08-17 10:11 pm #2 2004-08-17 10:11 pm #2 Measure the output at 8 ohms, then take the load off, and calculate the output impedance from the difference between the two values. Ordinarily we do this at 1Khz, and the DF is about 30 or so. ••• More options Share Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button.
