Hello.
I just built the Aleph3,the problem is that i have the half
of the bias current(1A total)at the three output Fet's.
How can i increase the bias current?
Bias can be adjusted by resistor -R113-( 47k originally). The higher value the higher current - at about 68k it should run on about 2,7A. I use in this position the trimpot.
Aleph 3 with 4 output devices
I have four matched IRFP240s and planing to build SOZ but after considering the cost I have changed my mind to Aleph 3. Since the Aleph 3 using 8 output devices, is it possible to use 4 output devices? It seems I must change the source resistor, but with how much resistant value?
Thank you for any response.
Yamin
Yamin
I would assume that you could make the Aleph 3 with half as many output devices. If you look at Mark's Aleph 4 at:
Mark's Aleph 4
He used half as many output devices as the design called for, due to a mistake in the service manual, and it works great for him.
I am not sure exactly what values that you would want to use for resistors, but I would imagine that you would use half the resistance.
Brian
gte619j@prism.gatech.edu
Mark's Aleph 4
Brian
- Aleph3 biasing question
