Aleph X - rootcause of absolute DC offset drift
Hello,
I have just successfully started up and adjusted my first monoblock of Aleph X (17,5V rails, 6,5A, 8 FETs). Everything ok so far – but I have a drift problem with the absolute DC offset. Maybe some freaks could give me further tricks to reduce it. I searched for this issue in the huge treads – but how to find it... So I start this tread!
The situation – as I understand it: my LM329 voltage reference brings the diff FET pair almost immediately to the final adjusted current, 2 x 11mA. So the biasing voltage at both 392R resistors is stabile after already some minutes. This stabile voltage brings the lower power CCS (Q2/Q11) very fast to a stabile current. It starts with 1,67A and reaches 1,68A per FET already after 10 min. Perfect so far...
But now the problem starts – the upper CCS – why ever – starts with 1,75A! Just after fully warmed up (taking 45-60min) it comes down to the same value of 1,68A per FET to get zero absolute DC offset. 1,75A – 1,67A = 80mA x 2 Fets = 160mA to be sink into R1/R4 with 2 x 100R. This forces 8V of absolute DC-offset directly after switching in! After 45 min still 1V.
Then I installed R48 and R49 with 4kOhm which were laying around. But this just reduces the value of the offset down to ca. 40%. So starting with 3,5V and drifting over 60min to almost zero strongly depending of the final temperature. Lower R values should improve the behaviour.
Lets analyse the rootcause to identify solutions. If my understanding is right the Basis-Emitter-voltage of upper npn Q3/Q8 must be drifting to cause this behaviour. But what makes this thing drifting?
- I cooled the npn, almost no change in offset.
- is it maybe a drift of the V1/V3 poti?
remark: my relative DC offset at the speaker is below 10mV any time, both amp branches work perfect symmetrically – drifting...
How are your experiences about the typical drift? Are there any ideas to compensate this drift if it is normal behaviour? Do R48 and R49 have an negative impact on the sound?
Thanks for your freaky answers, I am a bit of lost!
Bests regards
Klaus
Hello Klaus,
the variation in absolute dc offset is caused by variation of the dc bias of the diff pair. The tempco of the zener and the fet are not the same and bias current is changing until the temperature is constant.
I tried different zeners (a negative tempco is nice) and coupling of the fet to the case. This allowed for raising the feedback resistors (R46/47) to over 10k for a better sound.
Somewhere on the forum there´s a thread describing the details but I can´t find it at the moment (but I will look)
William
My experience is more in line with Klaus than with William. I use a different (JFET) current source and it stabilises quickly, as confirmed by the voltage across the diff pair drain resistors. The BJT of the Aleph current source is the cause of most drift.
I say this because if I have extremely good thermal coupling of output MOSFETS to each other (unmeasurable temp diff) and to the heat sink (case to sink 2 degC), so the drift of the output FETs largely cancel each other if Vgs stays constant. This I know as I tested each sets of FETs on heatsink at working voltage and current, using 9V batteries and trimpots to bias, to check thermal behaviour. And the current of upper and low FET sets, though both drifting with temperature, remains essentially identical (to about 10mA).
And I can measure much more drift on Vgs for the upper FETs (biased by the BJT) than the lower ones.
PS I do not use any bootstrap caps in the Aleph Current Source.
Patrick
The one and only
Joined 2001
Both are sources of drift, and also the varying Vgs of the
output devices. Since the simple version of the circuit has
no feedback for common mode effects, the absolute (as
opposed to differential) DC will drift. We use some resistive
loading to ground along with some comon mode feedback to
the Sources of the input devices to reduce this, and then
we adjust the offset after the amp has warmed up. You can
use a "servo" circuit if you like, but we have found these two
techniques plus some patience is adequate.
Thanks!
wuffwaff said:
Hi again,
thanks to all, especially wuffwaff and the one and only, for your hints.
Well, the reasons for the drift are well understood now, the causes and its relations are very complex. I will think about passive corrective measurements, like NTC etc. ... Maybe an improvement can be found. Maybe even an active regulator?
Klaus
The one and only
Joined 2001
An active offset regulator will work fine. If I ever get tired of
adjusting the pot in production, I'll put one in.
Keep in mind that the value of resistors from output to the
Sources of the input diff pair are very dependent on the specific
amplifier - 4.7K is a typical figure, but the overall performance
varies with the values, so you have to test them not only for
efficacy in controlling offset, but also distortion vs amplitude and
frequency and CMRR.
Klaus,
At the risk of repeating what others have said in previous threads the caveats of matching the input pair on both sides of the lower output stage are important.
For example in my baby X Aleph I matched the input pair within 5 mv and the outputs within 10mv. On testing it started out at about 8 volts and quickly dropped but I was not happy about the variations.
On my next effort I used jig with one 9610 as a biased reference and was able to match under 1mv because of the improved resolution of the meter.(measuring the absolute difference in Vgs)
I also carefully matched and selected matched sets IRFP240's for the lower output halfs and matched the bias and current gains and bolted the input pair together with a solid block of aluminium.
In the chassis the variation is typically under 100 mv after an hours warm up. I used to spend all night tweaking it to get it right on 0mv until it started to annoy my chickie babe!
The output resisters to ground are the important ones and have the most effect. I doubt however that even a 1 volt would cause a concern under dynamic conditions.
William,
Its been ages since I turned them off so i am sorry I dont remember. If l turned them off I would have to call the power station to turn them on again! The cat would also hate me.
I think is was something like 5-6 volts and it very quickly dropped to under 2 volts and then went down slowly.
regards
Macka
Ps. You know we do have a sense of humour down here in The Land Downunder.
Hi Maka,
thanks for your matching hints! Well, I am sure to have "hyper matched", too. We did a group buy and I had many FETs to find really perfect pairs with ongiong production serial number from the same lots. So I do not see a main reason here.
I will try to analyse in detail which device has which temperature drift. A first step towards constant conditions should be to bring the diff pair also onto the main cooling plates - so they also see refernce temp and heat up faster. Second step could be to play around with NTC or PTC bypasses around important Rs or to use cole Rs with negative temp drift (?).
I want to get rid of R47 and 48 - they can not be to helpful soundwise. Feedback to the bias, that is not so nice...
Regards especially to downunder
Klaus
Hi Klaus,
I tried a few things too to look for temp influence. It cost almost a whole can of ice spray but I found out that (in my amp):
cooling the diff pair had no influence on abs. dc
cooling the heatsinks of the output fets had no influence
cooling the current source for the diff pair had a big influence
cooling the zener had influence
I don´t think I tried the BC550 for the main current sources but I will do that next time.
william
wuffwaff said:
Hi Klaus,
william
Hi William,
thanks, very helpfull!!
I will try first do move the CCS FET for the diff pair from the PCB to the cold housing bottom plate. This should give a reference temp and reduce drift significantly. Afterwards I will play around with the cooling of the diff pair.
Zener drifts are not existing in my amp by using the LM329 voltage reference with low drift of just 50 or even 20ppm/K.
Klaus
i saw this on another thread:
From Nelson
1) Match parts for absolute and differential DC offset
2) Trim values with potentiometers for absolute and differential
DC offset
3) Common mode DC offset feedback from the outputs back to
the sources of the input diff pairs (for absolute DC offset)
4) Differential mode DC offset feedback (regular X feedback) for
5) Resistive loading at the outputs to ground (about 100 ohms
or so) which minimizes absolute offset drift
Works like glue....
