Aleph x one problem
I'm building l’Aleph x Gregary’s original version, I understood almost all. I have one problem:
When I’m setting bias V1, V3 and after V2 I must connect the loudspeakers right and left (the load) or I must not connect theloudspeakers. Only when I have finished the setting and Adjusting offset can I connect the loudspeakers?.
It's not necessary to have a load attached to the amp while adjusting the bias and offset. In fact, I would strongly recommend to NOT connect any loudspeaker while doing this. If something goes wrong with the absolute offset your speakers can be destroyed (they don't like offset very much).
Regards,
Xcel
