I have finally managed to build and test a channel of my Aleph-X, but I encountered a problem I couldn't solve: the offset between speaker terminals is always > 250 mV.
Supply rails are 15V, I use the standard Grey's schematic, output fets are IRFP 140. I made provision to install 8 of them (instead of the regular 4), but even with only 4 I never get to lower this offset.
I tried swapping different input pairs, trimming the drain resistors of the diff pair (R23-25) and even the source resistors of the lower fets (R6-41), but even if the absolute offset varies a lot the offset at the speakers terminals stays more or less the same.
My setup procedure was to set first the current of the two halves (in two steps since I noticed they slightly influence each other, probably via R46 and R47) and then use VR2 to minimize the offset.
Did I made something wrong?
Suggestions on how to get rid of this offset?
Cheers
Andrea
Cheers
Andrea
Andrea, congrats with your AlephX.
Did you measure with shorted inputs or something connected to them?
Did you wait long enough to let the amp warm up?
Did you look at this post? : http://www.diyaudio.com/forums/showthread.php?postid=225644#post225644
Keep us informed.
Ooh, and post some picture too please.
/Hugo
Keep us informed.
/Hugo
I had the same.... When you did not make any mistake in putting the circuit together, it comes down to one thing; better matched mosfet's!
The Aleph-X is way more picky to the matching of the IRF9610 pair and the 'lower' two IRF240's (the ones NOT in the current source) . I have matched about 8 pairs (with the procedure Nelson's describes in the A40 or A75) and swapped them in and out to get two good working pairs! I even swapped in and out the IRF240 to get a even measurement of the voltage over the bias resistor. Result: I have a steady 15mV without connected amp and about 30mV with a Aleph P connected in balanced mode!
See the other threads:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=15906
Edwin
Edwin
Hugo, I have the inputs AC coupled via 2,2 uF caps (one on each input) and shorted to ground.
For pictures I'll have to borrow the digital camera fron my workplace, as soon as things will allow me to.
I looked at the post, I'll try to swap some output Mosfets...
Edwin, the circuit works well, apart from this problem.
Will try swapping some other fets or their source resistors...
Cheers
Andrea
Cheers
Andrea
I tried both ways, before and after the capacitors (DC coupled) with no effect.
Yesterday I remembered that on the schematics of the Aleph 30 there were some "misterious" resistors, called "R8" and "R1" with a asterisk instead of a value.
In some thread it was said that they were used to trim the offset, thus their value was to be trimmed in circuit.
I used this method (R between D and S of one of the input fets) and it seemed that was finally possible to lower the offset close to zero.
Does this method produce some serious drawbacks?
Cheers
Andrea
Cheers
Andrea
First I set the currents of both sides to be equal, then with VR2 I can trim the absolute offset, but the differential (to the speakers) remains the same.
Only puting a resistor between the sources of the differential pair and the drain of one of them i can lower it.
Putting it on the drain of the other things got worse.
But the question remains the same: does this method have serious drawbacks?
The word to the experts (or to the )
Cheers
Andrea
Cheers
Andrea
Good news - but still something isn't OK
I swapped the lower fets (even if all 8 were matched within 10 mV), and trimmed one of the 392 ohm resistors at the drain of the diff input pair. This way the differential offset has been lowered to < 10 mV (even if varies a bit with temperatire), but the behaviour of the absolute offset puzzles me: it starts at about a couple of volts, then slowly decreases to about 300 - 400 mV. It stays around there jumping now and then to 500 mV; after that is keeps going negative, stops for a while at about - 300 mV and behaves as when of the positive side.
If I leave the amp for a long time without signal it seems to go in a sort of "negative thermal runaway", absolute offset becomes more and more negative and stops at about -7V.
In this situation it doesn't amplify any more, while if this doesn't happen output sinewawe is perfect.
I use 0R22 source resistors for the outputs and about 5A total bias, i saw Edwin uses much higher resistors (0.56), did I miss the relationship between them?
Cheers
Andrea
Cheers
Andrea
Re: Good news - but still something isn't OK
Perhaps you use less mosfet's... I use 16 mosfet's per channel. So 8 mosfet's per side so I have 4 times 4 mosfet 's parallel. To get to about 7A of total bias I use 0.56 ohm resistors (0.5V / 0.56 ohm = 0.89A * 4 mosfets * 2 sides = 7.1A). When you use half the amount of mosfet's you can use about 0.22 ohm!
My amplifier keeps running around but nevers gets higher to about -1V and +1V of absolute offset... It is very very heat dependend. I had about -500mV and when I opened the case 1 minute later I had about +400mV ... I read of simulair behaviour of Aleph-X; Peter Daniels had the same...
Edwin
P.S. I am actually running at a total of 6.7A I trimmed the bias a bit down...
Edwin
I use 8 mosfets, 4 per side.
Each one carries about 1.25 A, which means 275 mV on source resistors, slightly different from the 0.5V you use as "reference" value.... where does it come from?
On the Aleph30 manual this voltage value is of about 250 mV (and the equivalent of AlephX's R34 is 820 ohm), in the Aleph60 this voltage is 370 mV and the resistor is about 1K.. does this mean something?
Cheers
Andrea
Cheers
Andrea
Decreasing resistance of resistors from output to the ground and resistors from output to sources of differential pair decreases range of change of absolute offset with temperature.
Indeed, I didn't use the output to ground resistors but only the output to diff-pair sources. I used 2k, which is fairly low, but with good results.
/Hugo
Andypairo said:I use 8 mosfets, 4 per side.
I use 0.5V because this is the value used by Grey Rollins in the original first Aleph-X and by Nelson in the Aleph 2 and Aleph 4 which were both role models for my hyped up Aleph-X which runs at about 7A and on a voltage of -25V and +25V . I never thought of using another reference voltage. Actualy I am running at 0.45V because the lower bias! But with the VR1 and VR3 trimmers I can move it up and down over 0.4V to 0.7V or so...
Edwin
While testing I also noticed that while the differential output can output a perfect sinewave of more than 13Vrms, the single ended outputs dont'.... did anyone noticed that also?
What did you mean? Isn't it a bridged amp?
Well, I mean that, running it unbalanced mode, the output waves of the two halves (referenced to GND) are very different in amplitude (but this seems normal).
The funny thing is that, when the input signal is strong enough to make the more "driven" side clip the other half compensates for it, giving a ugly waveform that, summed to the clipped other, makes a almost perfect output waveform.
I wish I had a digicam... a image is better than 1000 words sometimes...
Another thing: I tried to see on my scope the AC current flowing in the lower mosfets but, while I expected to find a sine wave, I only see it at very low levels; raising the input voltage it becomes a more peaky waveform.
The current on the upper side is instead perfectly sinusoidal: does this mean that the current source is doing all the job?
Cheers
Andrea
Cheers
Andrea
After reading through various posts of the original Alephx thread
my guess would be that there is something wrong with your
diff-pair current source.
-7V is simply not normal. Are you sure you have no bad soldering or wrongly connected components?
Also, the 1k5 resistors could indeed be too low.
What are your values of R12/R34?
Greetings
/Hugo
Andrea,Andypairo said:absolute offset becomes more and more negative and stops at about -7V.
Greetings
/Hugo
Jarek - the link you posted was very useful, I followed some of Nelson's suggestions (R46-R47 are now back to 4.7k) and things got better.
The big change was when I also changed R14 (R31) and R32 (R15) to 1.5 k and now things are going even better.
Hugo - The waveforms I obtain are now quite good, the only thing left to trim is the AC gain of the current source, which seems to have too much gain: if I measure the AC current on the low side I get about 300 mA pk-pk, while on the positive side I have almost 900 mA pk-pk... maybe R12/34 is too high (1.2k, as from Grey's schematic) ?
I'll try changing it and see what happens...
Cheers
Andrea
Cheers
Andrea
- Aleph-X offset problem
