Aleph P v1.7 Muting Circuit
I built the power supply for the Aleph P v1.7 preamp which works fine, except when I connect the muting circuit. When I do, the regulated 60v immediately jumps up to the unregulated level of ~85v - with or without the relay coils connected. I have tried numerous fixes. I can't find anything similar in a search of the posts. Has anyone had a similar problem?
In tests with the mute circuit removed, I found any resistance in parallel with the D-S of the main IRF610 (Q23) has the same effect, i.e. connected like R110 and R111 in the differential part of the mute circuit......
Thankful for such a simple answer. Indeed the power supply needs to be under load. With the regulated output loaded by a 6k resistor the PS behaves beautifully. I wasn't courageous enough to actually hook it up to the main board until it tested right. PS, I'm building the Aleph P v1.7 to drive the Mike Rothacher designed Circlotron.
