Hi all,
Does anyone have any idea of what remote control can be used with this preamp, or any idea of which protocol is relevant.
TIA
John Caswell
TIA
John Caswell
John:
Dantimax (http://electronics.dantimax.dk/) offers remote control kits that can be used with the Aleph P. In fact, I'm building one right now using the following from Dantimax: Control2, C2Panel1-2, RelVol3 (with 1K resistor sets), Input2 and the SRU1010 handset. I purchased the transformer and display elsewhere, but Mikkel can usually supply them as well.
This is the second time I've installed a Dantimax remote control system in a preamp. Mikkel provides great products and support. Highly recommended.
Regards,
Scott
Regards,
Scott
Also recomend kits from Dantimax, beutifull and simple designes. I bought VolControl2, RelVol3 and RC5TX1 boards.
I have one offtopic question...what is the best value for Aleph P1.7 attenuator? Is it OK 2kohms or is it better lower value?
felix the cat said:Also recomend kits from Dantimax, beutifull and simple designes. I bought VolControl2, RelVol3 and RC5TX1 boards.
2kohm is just fine....but....the lower the better for the noise figure.
Be carefull that you want to reach out at least a gain of +3-3.5dB to be able to manage very low recorded discs/low input sensitivity power amp and have a little extra swing for particular cases(about 1.5 in linear).
- Aleph P preamp
