Aleph-P finished!
Special thanks to Klaus who helped me a lot throughout the DIY work. It' had been painful to figure out the bug that I carelessly made by misreading the resistance of 22.1ohms and 33.2ohms as 221ohms and 332ohms respectively. He simply gave me a hand that took me out of serious troubles.
The following picture shows the main pcb
PatPet said:
The Blue Led act as constant voltage source as part of the power regulator...
Out of curiosity, what is the voltage across the blue LED? I've never used one, but I found some in rather, er, minimal packaging at a local electronics shop. Other than stating that it would produce 10 mcd illumination at 20 mA bias, there was zero information about it.
