Re: Aleph P1.0 volume control
panos 29 uses remote controlled motorized PANASONIC pot in Aleph L - not volume control from Aleph P 1.0!
So
Did one of you ever build Aleph P 1.0 volume control?
Does it work or not?
mpopovics said:I am currently working on it, but only in single ended mode.
Panos29 has biult it. It works fine.
Check out for Panos29 posts, Alpeh L construction both here and on the passDIY.com.
So
Check out those
Here is the link, check for Aleph L in second part of the thread.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=2206
You will find there zipped pdf's. This is working, but it is for single ended use. If it is working in single ended mode, it should work also in balanced mode...
Here is another picture, my Alpeh L version, with Aleph P1.0 volume control in single ended mode also.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=4598
- Aleph P 1.0 balanced volume control
