Is it possible for an aleph L to drive successfully two aleph 3 for
vertical biamping?
It will see only half impedance of the poweramps (11500 ohm).
Thanks.
vertical biamping?
Thanks.
I tought it was impossible for the "before 3 o'clock" positions of the attenuator; isn't it a passive preamp in that situation?
Thanks .
Stefano
Thanks .
Stefano
Thanks mr. Pass,
so I can use two Aleph 3 for biamping without driving problems.
I thought I had to use necessarily the Aleph P.
Very good.🙂
Very good.🙂
The question you should be asking is if your preamp can drive your crossover...after all, that's what the preamp will see, not the Aleph 3s.
Grey
Grey
Hallo Grey,
this is passive vertical biamping (without electronic x-over). Maybe I'll use a simple 6db/oct. filtration for high frequencies.
Regards.
Stefano
Regards.
Stefano
What sort of filter are you using and is it before or after the amp(s)? Assuming the filter to come before the amp (by far the most common arrangement, though I've known one or two people to try the filters afterwards), the impedance presented by the filter itself is the issue. One you get beyond the pass band, the rolloff presents an increasing impedance to the preamp. For example, if you have a 2kHz high pass filter for your midrange and tweeter, 100Hz signals find a pretty high impedance (how high depends on the filter and questions such as what the crossover slope is).
Grey
Grey
I'm not doing this by myself (I'm not even able to solder 🙂),
But the cross is about 1000hz (Tannoy custom with hpd 12") and the technician said he will put the simple filter before the left channels of the amps(the right ones will remain full range for woofers) , maybe before the left outputs of the preamp.
I'm not able to explain the thing better than this,excuse me.
Regards.
Stefano
Regards.
Stefano
- aleph L+aleph 3+aleph 3
