transformer
which transformer is recommended for an Aleph J-X monoblock?
I´m thinking about 500VA up to 1000VA.
Will be 500VA enough?
Thanks,
Marcel
Thanks,
Marcel
Hi Sonidos, Could you put me also on the Wiki. I would like to get boards for two aleph-jx and also the boards for the power supplies. So i think that means
4 aleph-j boards
2 boards for x-ing
and two power supp. boards
4 aleph-j boards
2 boards for x-ing
I would like to get 2 AJ-X boards and 2 PS boards (for 2 mono block)
wiki is locked right now to edits
Ok, I saved the coding to add you guys on the list. But the wiki is locked right now for admin approval. I'll follow up later. PM me if I forget.
Alettagla, I believe a single board includes 2 aleph J's and the board for x-ing. So I will put you down for 2 boards...that should get you what you want.
4 aleph-j boards
2 boards for x-ing
Hey.
I want to register my interest, but the Wiki page is currently blocked ...
I want to be put down for 2 AJ-X boards, and 2 PSU boards.
I heard back from Jason and he is working on it. I work all day testing software, and now this!!! The gods do not like me!!! 😀
(edit: dagnabbit! The wiki gods like me! Looks like it is working again! woohoo!)
Ok, those that had trouble editing the wiki, please check the numbers and make sure the data is correct.
COX77 - you stated 2 Aleph, so I put you down for 2 boards and no psu boards.
Hi sonidos, thanks for putting me on te wiki.
Probably due to the problems with the wiki page you forgot to put on the wiki my interest for the psu boards.
Could you still put me on for these psu boards?
Im very curious as to anyone has already finished this amp and, if so could report about it.
thanks
thanks
ma_coule, my pleasure. For all those who are comfortable with wikis, go right ahead and post away! But if you feel challenged, please post here or PM me and I will add you on the list. I only ask that you go back to the wiki and confirm that I have it right. When I have time, I will add a total below the table, tally the total and add date/time of my totals editing so you will know if it is fairly up to date.🙂
Then, we'll leave it up to Peter to see if we have met the minimum to get this moving.
On which list? 😉But if you feel challenged, please post here or PM me and I will add you on the list.
- Group Buys
- Aleph J-X pcb group buy
