Aleph J new build testing
thanks
do what Dennis said
not enough voltage across that drain resistance, if both trimpot and resistor are populated
remove 1K, prior to that back down with trimpot setting
not enough voltage there, not enough Ugs for lower mosfet, thus not opened enough, resulting in positive DC Offset
Thanks Dennis,
Actually, i asked this question some time ago when i was designing the pcb, i must have misunderstood the reply and kept R7, now all is clear 👍
I see now Vgs should be about 4.3v, is that correct?
R7- Is the fixed 1k resistor removed in place of the pot? Then once the offset is fixed is the pot replaced with a fixed resistor of the required value? (Same question R27 re bias)
