Aleph J illustrated build guide
Hi chaps, just powering up my Aleph J for the first time! PSU ok on bulb tester and producing the expected voltage but when I attach an Aleph board, the bulb lights then dims and then brightens a bit again finally settling on what I would call quite bright but not as bright as a 100w bulb would normally be.. Both boards have the same result. Bias reads about 340mv and offset 140mv. Am I being too cautious in thinking there's a problem or should I just try without the bulb tester next??
Looks like the power supply draws a bit of current, which makes the bulb light up. This is how it's supposed to be! Someone else may know more about the right bias values, but I say if there is no bangs or smoke you're ready to go without the bulb tester. Then adjust the bias and offset, hook up a (cheap) loudspeaker and see if you get music!
Absolutely fantastic! Put the lid on (resting) let it warm up for 30min or so, set bias to 400mV and re-check offset. Let sit another 30 with the lid on, measure again, if stable, listen and enjoy!
The Aleph is a beautiful and beguiling amplifier, you will love it! Enjoy :yes:
Your output stage is floating, there's no current running through the output MOSFETs.
So, check the input JFETs and make sure the voltage drops are correct. This will generate a required voltage drop across R7, to "open" the "amplifying" MOSFETs into a conductive state.
The other, current-setting MOSFETs, are set into a conductive state by Q4 Vce. This also needs to generate 4.3V to let the current flow (through the output MOSFETs) from the positive rail.
See the 3 voltages in the attachment, measure yours, provide few photos...
