6 per channel? I.E., 3 current sources and 3 outputs?
Or 6 outputs and 6 current sources per channel? (You will need a fan.) (Or 2)
If you want to use just the ones that will mount on that board, because you have such tall heatsinks, I wouldn't break the boards and just use them as one piece.
I had to look at the Aleph60 schematic, and yes, it has 6 CCS fets and 6 outputs per channel.
It will heat your house. Neat!
You will need another set of the BrianGT boards in order to use them for their daughterboards. My understanding is that you can daisy-chain them in series to get as many outputs as you need.
So, I guess we have a bit of misunderstanding here. I will try to clarify:
The chassis I posted above is for one channel -- monoblock. It has two .2 c/w heatsinks. I am assembling one first and then copy it.
Here is the photos of what I have now:
Ready to be stuffed.
So my question is still: how to hook up these daughter boards in parallel in the best way?
![te7u6ysu.jpg](https://img.tapatalk.com/d/12/10/04/te7u6ysu.jpg)
aha. this seams just fine
the two paralell boards are hooked up with 3 cables. (at the end of the board. and 4 cables from one board to the front end board
this is marked on the front end board![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
EDIT: not the end of the boards. i'll find my boards and get back to you
just a min.
It looks like the daughterboards have 2 sets of connections, so you can attach one to the main board, and then the daughterboards together. Do that for each side (CCS and amp)
correct
Cool, thanks. Is +-45V about right for the A60?
+/- 34V isn't it?
Are you using BrianGT boards? I am heaving difficulties populating them, so I would appreciate any help...
The A30 is pretty straightforward, what are you having problems with?
+/- 34V isn't it?
I am going by Aleph-2's schematics, and it uses 45v?
aleph2 is not aleph60. aleph2 is a 100W classA amp.
- Aleph 60 building thread
