Hi All
Excuse my poor English but I come to seek of the assistance for a new project.
I ordered PCBs and I plan to build Aleph 5 in version double mono.
Here is the problem: I would like to draw up a list of the components for Aleph 5 adapted to the establishment of Brian PCBs (mini Aleph) to place an order at digikey from France. The lists of components exist on the Net but I did not find the establishment adapted to the diagram of Brian. Could you help me to supplement the following list ?
By advance thank you
Daniel
Amplifier board Brian GT Aleph 5
Capacitors
C1-C3
C4
C5
C6
Diodes
D1-D5
Resistors
R0
R1
R2
R3
R4
R5
R6
R7
R8
R9
R10
R11
R12
R13
R14
R15
R16
R17
R18
R19
R20
R21
R22
R23
R24
R25
R26
R27
R28
R47
R48
R49
Transistors
Q1-Q3
Q4-Q5
Q6-Q7
Output boards
Q8-Q13
R29-R34
R35-R40
Daniel
Capacitors
C1-C3
C4
C5
C6
Diodes
D1-D5
Resistors
R0
R1
R2
R3
R4
R5
R6
R7
R8
R9
R10
R11
R12
R13
R14
R15
R16
R17
R18
R19
R20
R21
R22
R23
R24
R25
R26
R27
R28
R47
R48
R49
Transistors
Q1-Q3
Q4-Q5
Q6-Q7
Output boards
Q8-Q13
R29-R34
R35-R40
Here's the link to Brian's website. It includes a list of parts. The bias resisters needs to be changed for and Aleph60 (R12, R13, R17).
http://www.diyamps.com/aleph/aleph.shtml
-David
-David
Post #2
-David
Hi david
Thanks for your reply. For a Aleph 5 are all the other components the same of Aleph 30 except R12,R13,R17 ?
-David
Hi david
aleph 5 with Brian GT boards
Hi all
i found some corespondances for the values of some components as their establishment on the diagram of Brian but this is not simple for me.
Are they exact and would have you to them complements?
Amplifier board parts for 1 channel Aleph 5 BrianGT
component designation value digikey part # quantity
Capacitors
C1-C3 220uf P10326-ND 3
C4 10pf 338-1090-ND 1
C5
C6
Diodes
D1-D5 9.1v zener 1N4739ADICT-ND 5
Resistors
R0
R1.R9
R2.R15 100K 2
R3.R10
R4.R7.R8.R11.R29-R34 221 PPC221XCT-ND 11
R5 4.75K PPC4.75KXCT-ND 1
R12
R13
R14.R16 1.50K PPC1.50KXCT-ND 1
R17.R18
R20 1.00k PPC1.00kXCT-ND 2
R23-R26.R35-R40.R47.R48 0,47 P0.47W-3BK-ND 4
Transistors
Q1-Q3 IRF9610 IRF9610PBF-ND 3
Q4-Q5 ZTX450 ZTX450-ND 2
Q8-Q13 IRFP240 IRFP240PBF-ND 6
Hi all
Capacitors
C5
C6
Diodes
Resistors
R0
R1.R9
R2.R15 100K 2
R3.R10
R12
R13
R17.R18
Transistors
HI all
Research continues and I could find on the Net the values with the following establishments.
1-could say itself to me if they are exact?
2- I miss it the values for;
-C6 ?
-R 0 ?
-R 12 ?
-R 13 ?
-R 17 ?
For those which have already condtruit a aleph 5 with these PCBs would have this information?
Thank you
Amplifier Brian board parts for 1 channel ALEPH 5
Capacitors
C5 1nf PS1H103G-ND 1
C6 javascript:smilie('')
smash
Diodes
Resistors
R0 ? ? 1javascript:smilie('')
smash
R1.R9 10.0K PPC10.0KXCT-ND 2
R2.R15 100K PPC100KXCT-ND 2
R3.R10 68.1K PPC68.1KXCT-ND 2
R4-R8-R11-R19-R21-R22-R29-R30-R31-R32-R33-R34 221 PPC221XCT-ND 12
R35-R36-R37-R38-R39-40 1 1 Ohm - 3W 6
R12 ? ? 1javascript:smilie('')
smash
R13 ? ? 1javascript:smilie('')
smash
R17 ? ? 1javascript:smilie('')
smash
R18 392 PPC392XCT-ND 1
R23-R24.R25-R26.R27.R28 0,47 P0,47W-3BK-ND 6
Transistors
HI all
-C6 ?
-R 0 ?
-R 12 ?
-R 13 ?
-R 17 ?
Thank you
Capacitors
smash
Diodes
Resistors
smash
smash
smash
smash
Transistors
Hi
Thanks Steen and dw8083 for your replies
Here the values with the correspondences of the circuit aleph. R6 is optional but which could be its value?
Edoirt
Amplifier board
Capacitors value équivalences shéma Aleph
C1-C3 220uf C5 C10 C9
C4 10pf C8
C5 1nf C7 0.47nf
C6 47nf
Diodes équivalences shéma Aleph
D1-D5 9.1v zener Z1-Z5
Resistors value équivalences shéma Aleph
R0 3.0 3W
R1 10.0K R2
R2 100K R6
R3 68,1K R4
R4 221 R12
R5 4.75K R13 10K
R6 Optionnel
R7 221 R9
R8 221 R11
R9 10K R3
R10 68,1K R5
R11 221 R10
R12 453 R21
R13 221K R19
R14 1,5K R17 4.75K
R15 100K R7
R16 1.5K R18
R17 75 R16
R18 392 R14
R19 not used R52-54
R20 1.00K R20
R21 221 R15
R22 not used R28-30
R23 0,47 R22
R24 0,47 R23
R25 0,47 R24
R26 0,47 R25
R27 not used R64-66
R28 not used R40-42
Transistors value équivalences shéma Aleph
Q1-Q3 IRF9610 Q2-Q1-Q3
Q4-Q5 ZTX450 Q4-Q5 MPSA18
Q6-Q7 not used
Output boards value équivalences shéma Aleph
Q8-Q13 IRFP240 R28-R30 Q18-Q20
R29-R34 221 R28-R30 R52-54
R35-R40 1.0 3W R40-42 R64-66
Hi
Edoirt
Amplifier board
C4 10pf C8
C5 1nf C7 0.47nf
C6 47nf
R0 3.0 3W
R1 10.0K R2
R2 100K R6
R3 68,1K R4
R4 221 R12
R5 4.75K R13 10K
R6 Optionnel
R7 221 R9
R8 221 R11
R9 10K R3
R10 68,1K R5
R11 221 R10
R12 453 R21
R13 221K R19
R14 1,5K R17 4.75K
R15 100K R7
R16 1.5K R18
R17 75 R16
R18 392 R14
R19 not used R52-54
R20 1.00K R20
R21 221 R15
R22 not used R28-30
R23 0,47 R22
R24 0,47 R23
R25 0,47 R24
R26 0,47 R25
R27 not used R64-66
R28 not used R40-42
Q6-Q7 not used
Banned
Joined 2002
Re: aleph 5 with Brian GT boards
It's only needed when all fets are really really closly matched. I have tried it with it in and it makes no difference in sound at all.
edoirt said:Hi
Edoirt
HI all
OK for R6 jleaman but there is still a mystery for me ;
The corespondances between the 2 diagrams reveal some different values;
- R3=R4 68.1K/10K
- R5=R13 4.75K/10K
- R10=R5 68.1K/10K
- R14=R17 1.5K/4.75K
Which are the values to be retained?
Those of the diagram of Brian or those of the Aleph 5 diagram ?
Edoirt
HI all
- R3=R4 68.1K/10K
- R5=R13 4.75K/10K
- R10=R5 68.1K/10K
Edoirt
Aleph 5 with Brian GT Board
Hi Everybody.
I'm building an Aleph 5.
I have a question about a détail of the schématic diagram aroud Q5 (see the File attached).
Why ,in this schématic, the cap C5 (value 1NF) is connected between the Base and Collector of Q5 (ZTX450), and in the original Schématic of Nelson Pass we can find this same cap ( Value 47NF) connected between the Collector and Emitter of Q5 (MPSA18).
thanks for your response.
Best regards.
Raydiven
Hi Everybody.
Best regards.
Raydiven
Hello, I just received my BrianGT Aleph boards as well, and as I couldn't find any component lists on the chipamp site nor coming with the PCBs, I spent my afternoon in the sun, trying to figure it all out using the original Aleph 5 service manual schematics and the PCBs at hand. Now I think that worked out ok - there are just a few changes that I noticed:
-The 10k resistor called R8 on the original schematics connecting the unbalanced input to the balanced + in is missing (probably neither very important, nor hard to fix).
-the 680pF cap called C6 in the original schematics, which is connecting C7 and R8 (or C4/R15 on the BrianGT boards) to Q4 and the G- connector, is missing completely. I have the feeling that this would be a rather important component, and I'd rather have it in my circuit than not - does anybody know anything about the results of not having a cap in this place, or how to get it in there without too much hassle?
My component list so far (BrianGT board numbers):
R1: 10k Ohm
R2: 10k Ohm
R3: 100k Ohm
R4: 221 Ohm
R5: 10k Ohm
R6: not used
R7: 221 Ohm
R8: 221 Ohm
R9: 10k Ohm
R10: 10k Ohm
R11: 221 Ohm
R12: 453 Ohm
R13: 221k Ohm
R14: 4,75k Ohm
R15: 100k Ohm
R16: 1,5k Ohm
R17: 75 Ohm
R18: 392 Ohm
R19: not used
R20: 1k Ohm
R21: 221 Ohm
R22: not used
R23-26: 0,47 Ohm, 3 Watt
R27,28: not used
R29-34: 221 Ohm
R35-40: 1 Ohm, 3 Watt
C1-C3: 220 µF
C4: 10pF
C5: 47nF
C6: not used
C7 (not on board yet): 680 pF
Q1-3: IRF9610
Q4,5: MPSA18/ZTX450
Q8-13: IRFP240
Any comments/critizism/advice is absolutely welcome!
Christian
R1: 10k Ohm
R2: 10k Ohm
R3: 100k Ohm
R4: 221 Ohm
R5: 10k Ohm
R6: not used
R7: 221 Ohm
R8: 221 Ohm
R9: 10k Ohm
R10: 10k Ohm
R11: 221 Ohm
R12: 453 Ohm
R13: 221k Ohm
R14: 4,75k Ohm
R15: 100k Ohm
R16: 1,5k Ohm
R17: 75 Ohm
R18: 392 Ohm
R19: not used
R20: 1k Ohm
R21: 221 Ohm
R22: not used
R27,28: not used
R29-34: 221 Ohm
C1-C3: 220 µF
C4: 10pF
C5: 47nF
C6: not used
Q1-3: IRF9610
Q4,5: MPSA18/ZTX450
Q8-13: IRFP240
Christian
Hello,
i got Brians miniAleph Boards too and worked the forums to find out any information why Brian skipped/changed parts/values.
btw, thx Brian , these red boards are just phantastic
great site, good work !
To PolishedSteel :
The Original R8, at the unbalanced input, is a 1000Ohms,
and yes its missing in Brians boards. I wonder why.
Your Component List is wrong. Go see the xls-sheet at :
http://www.diyamps.com/aleph/docs/minialeph-parts_list.xls
Amplifier board
Capacitors value
C1-C3 220uf
C4 10pf
C5 1nf
C6 47nF
Diodes value
D1-D5 9.1v zener
Resistors value
R0 3.0
R1 10.0K
R2 100K
R3 68.1K
R4 221
R5 4.75K
R6 optional
R7 221
R8 221
R9 10.0K
R10 68.1K
R11 221
R12 825
R13 47.5K
R14 1.50K
R15 100K
R16 1.50K
R17 392
R18 392
R19 not used
R20 1.00k
R21 221
R22 not used
R23 0,47
R24 0,47
R25 0,47
R26 0,47
R27 not used
R28 not used
R47 0,47
R48 0,47
R49 not used
Transistors value
Q1-Q3 IRF9610
Q4-Q5 ZTX450
Q6-Q7 not used
Output boards
Q8-Q13 IRFP240
R29-R34 221
R35-R40 0,47
To Brian or any1 that wants to contribute:
1. Brian added R0 3Ohms 3Watts, pulling the zehner diodes to gnd. why?
2...solved..
3. Original R13 / Brians R5 have different values.(10k/4.75k)
4. Original R17 / Brians R14 have different values (4,75k/1.5k)
5. ...solved...
6. Original C7 47nF sitting between C and E of this MPSA18 has changed position and value to 1 nF in Brians. Now between C and B of this ZTX450.
7. The Original C6 680pF is missing...
I cant wait to get the parts together to build my 1st Aleph-5 , hehe.
I just finished my PS1-Powersupply with 2 toroid transformers.
Used LT1084 for each Voltage-rail muuuuahhrrharrr
Unluckily , this dude at the shop sold me the 12Volt fixed ones and i didnt noticed it untill i ran the tests this morning...
now i had to order 2 new ones at reichelt.....
Thank you Nelson Pass , it was the simplicity of the circruity that made me consider diy. ...bows..
To PolishedSteel :
Amplifier board
Capacitors value
C1-C3 220uf
C4 10pf
C5 1nf
C6 47nF
Diodes value
D1-D5 9.1v zener
Resistors value
R0 3.0
R1 10.0K
R2 100K
R3 68.1K
R4 221
R5 4.75K
R6 optional
R7 221
R8 221
R9 10.0K
R10 68.1K
R11 221
R12 825
R13 47.5K
R14 1.50K
R15 100K
R16 1.50K
R17 392
R18 392
R19 not used
R20 1.00k
R21 221
R22 not used
R23 0,47
R24 0,47
R25 0,47
R26 0,47
R27 not used
R28 not used
R47 0,47
R48 0,47
R49 not used
Transistors value
Q1-Q3 IRF9610
Q4-Q5 ZTX450
Q6-Q7 not used
Output boards
Q8-Q13 IRFP240
R29-R34 221
R35-R40 0,47
2...solved..
5. ...solved...
- Aleph 5 with Brian GT boards. (help)
