ALEPH 5 wiring diagram
I thought they were for the input signals alone. Will it cause any harm or noise issue if I connect the supply GND to the same point?
Also, what about the negative terminal of the Speaker? Only +ve is there on the amp board.
Best regards,
BP
there are enough pictures of original Alephs , study them and learn
First Watt amps are made on same principles/approach , regarding physical layout and power wiring
Nobody can't teach you pcb layout wizardry in fast way .... that's sorta multidisciplinary Voodoo , when one have it in hands/brain
KK's pcbs aren't best specimens to study , search forum for other Aleph pcbs , you'll find necessary graphical files , then you can build on that experience
plenty of info around - invest some elbow grease and you'll learn more than from answers on few (random) questions
