Does anyone have a view as to whether a production Aleph 4 is capable of driving a pair of speakers with a nominal impedance of 4 Ohms and a sensitivity of 92dB/W@1m?
My understanding is that the Aleph 4 does NOT increase power into lower impedances (though I'm not sure where I got this from).
I'd really appreciate your thoughts on this. Now just let me know.
Mani.
Mani.
say that yor Aleph 4 have at least 25% more power on 4 ohms than on 8
that's usual ratio for almost all Aleph amps
92db/w/m seems pretty adequate even for lesser Alephs , under condition that they have no wild impedance modul
manisandher,
with low impedance speakers Aleph shows its ugly side (a CCS tricked into believing that he's a part of push-pull team).
And make sure not to take advice on this matter from people who own and listen to 16 Ohm speakers - not even if they have a monkey on the shoulder 😀
Is that what that is?
Maybe a BA2 or F5 would be better.
I am sure you could tweak the ccs in the aleph to better match 4ohm speakers though, but maybe it is not worth the effort.
As a suggestion I would aim for 24V to 30V rails and 4A bias current.
manisandher,
......- not even if they have a monkey on the shoulder 😀
wrong ;
for all this years you didn't catch that I'm siting on her shoulder
mani - you know to judge by your own ears ;
nothing will be better than hear exact combo in your place
No, please don't do that - those pony tails are so you.... 😀wrong ;
Abosolutely - making one's own judgment is the best solutionmani - you know to judge by your own ears ;
The Aleph 5 does 90W into 4 ohms, AC gain is higher. You can also increase the AC gain in the Aleph 4 if you wish. Check out the spreadsheet for the X amps or the old Aleph spreadsheet if you can find it. I use a slightly tweaked Aleph J for my Seas Thors with fine results.
- Aleph 4 - the right amp?
