Aleph 30 weak bass
Hi, I have an Aleph 30 from about 2004 that exhibits weak and distorted bass; midrange and treble seem fine. I've measured the rail voltages, bias currents and output offsets and all seem fine. Although physically, everything looks fine, I'm suspecting the 16+ year old power supply caps. Does that seem reasonable, or is there something else I should be taking a closer look at?
It's been several weeks already. I pulled one of the caps off the board and it measures 8750 uF (nominal 10,000 uF), so a little low, but still within 20%. Assuming the rest of them measure about the same, that doesn't seem too serious a loss. So, I'm at a bit of a loss right now,
Could have higher than normal ESR. Also there's C103, which is 220uF, 35V.
However, if you mainly listen to LPs, maybe the colder winter ambient temperature
is stiffening up the stylus. If so, can you try another source?
Actually, the source is digital. And I’m not hearing the issue with a 17 watt mini-Aleph or a Hafler 9180. So I’m pretty confident something is amiss with the Aleph 30. You bring up an interesting point re: ESR. I’m not sure how to determine if that’s the issue.
If you have built any other amps or have a PSU with new caps, perhaps a test with a different PSU could give you some confirmation.
Another suggestion - disconnect one channel (from + and - rails at least) and see if the reduced load changes the response for the channel still connected.
value, if not really way outa specs, is not what's most important
as Boyz already pointed - ESR is what's in play there
anyway , as good new caps are not costing arm and leg, just replace them with new ones
Not really an option this time around. This is one of Nelson's Volksamp Aleph 30s. I'd rather not bugger it up too severely 😉
