I built an Aleph 30 and it works ok. The power supply as a 300 watt torroid 2x18v (ac). I should have about 25V after the rectifier bridge, however, when measured with the multimeter I get 17 v (ac) and only 20,5 V (DC). The current is 5Amp and have 6 capacitors of 15000 uF
Is it normal to get nearly 3,5 volts across the rectifiers (datasheet says 1,2V)? What could be wrong?
